Workato
Come running back
Mile {{ mileLabel }} of 5
Book a reconnect call ↗
{{ s.label }}
{{ s.value }}
{{ m.label }}
We’ve got
unfinished miles.
We’ve already covered some ground together, and there’s a lot more road ahead. Since we last spoke, AI and Workato have both moved fast. The laces are step one.
Mile
01
Mile one
A little something for the next step.
Let’s reconnect and see what’s changed for you, and what’s changed in the platform. If we're headed in the same direction, we'll get you something to attach your new laces to.
Flat-lay: teal Workato shoelaces on white
Back of the card with the QR code
Step one of two
Laces now.
Shoes if we run together.
Mile
02
Mile two
The timing might be different now.
Budgets reset. Priorities shift. Roadmaps get rewritten. Whatever put things on pause a few quarters ago may not still be true today.
Then
Today
{{ s.kicker }}
{{ s.thenTitle }}
{{ s.thenBody }}
{{ s.nowTitle }}
{{ s.nowBody }}
We’re not asking you to sit through the same pitch, only whether enough has changed to justify a second look.
Mile
03
Mile three
The foundation still holds. The opportunity has expanded.
Workato still connects the applications, data, APIs, and processes that keep the business moving. Today that foundation extends across AI and agents through one Control & Execution Platform.
What’s new since we last spoke
Hover a card to trace it through the platform below
{{ c.num }} {{ c.title }}
{{ c.body }}
Trace this path
{{ a.label }}
Control plane
{{ c.label }}
Execution plane
{{ c.label }}
{{ s.label }}
Mile
04
Mile four · the opportunity
Custom shoes could be the next step.
If we discover we’re headed in the same direction, the laces won’t be the only thing in the box. A custom pair to help you go the next mile, customized to your color and liking (no Workato-branded kicks here).
Custom Workato running shoe with teal laces
If an opportunity opens
Finish line
Ready for the next mile?
Thirty minutes, no re-run of the old deck. Just what’s changed and whether it maps to where you’re headed.
Workato
Contact: (844) 469-6752
